Does the Samsung S4 and S5 support micro SDXC format 128GB?
A
AC Question
does samsung s4 and s5 support micro SDXC format 128GB?
What is the maximum limit of memory that can be used on my Samsung s4 and s5? Also, do they support micro SDXC format?
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Since the answer to your second question is yes, the answer to the first one is "up to 2TB". (Any device that supports 64GB orr higher supports SDXC. Hoe tightly the standard is adhered to is up to the manufacturer, though [some devices may accept SDXC cards formatted as FAT32, others may require the card to be formatted as exFAT, as per the spec.)
johndoe11
