1. AC Question's Avatar
    I just got 5/SD cards from wish.com which means they came from China. How can I format them. 1 of them is for my cell Phone that is a Kyocera hydro air. Thanks
    01-27-2016 05:27 PM
  2. Rukbat's Avatar
    They usually come formatted. Just put one in the phone. If it needs to be formatted, the phone will tell you. (Then you can use a card formatting app or you can restart to recovery and format it from there.)
    01-28-2016 12:05 AM
  1. Replies: 1
    Last Post: 02-02-2016, 07:05 AM
  2. Why is my Motorola Nexus 6 network reception is poor?
    By munnakha05 in forum Google Nexus 6
    Last Post: 01-29-2016, 04:12 AM
  3. How to us Low Energy bluetooth to connect to a bluetooth device?
    By AC Question in forum Android 6.0 Marshmallow
    Last Post: 01-28-2016, 12:08 AM
  4. What can I do to pair a keyboard with my Tab S2?
    By AC Question in forum Samsung Galaxy Tab S2
    Last Post: 01-28-2016, 12:07 AM
  5. cant down load pictures from my text why
    Last Post: 01-27-2016, 05:00 PM
