1. AC Question's Avatar
    Wondering if I should upgrade from a Galaxy s5 to a note 5? Thanks.
    01-28-2016 12:13 AM
  2. Von Spradlin's Avatar
    Yes, but why stop there? You should make sure to get a Samsung Tablet and Gear2 smart watch to go with it.
    belodion likes this.
    01-28-2016 02:09 AM
  3. belodion's Avatar
    And why stop there? I believe that Samsung build ships, too.
    01-28-2016 03:27 AM
  4. AlphaTango414's Avatar
    Note 5 is a great device but if you use the water proofing of the s5, don't forget the Note 5 has no factory water proofing/resistance and currently has no waterproof cases available.
    01-28-2016 04:09 AM
  5. MikeCorsten's Avatar
    I thought you might have headed towards fridges or washing machines first
    01-28-2016 04:17 AM
  6. Von Spradlin's Avatar
    Yea, I thought that escalated quickly.
    belodion and MikeCorsten like this.
    01-28-2016 06:36 AM
  7. belodion's Avatar
    Well, a friend once told me that Samsung is a huge company that makes everything from toilet paper to ships so I thought I'd just go for ships.
    MikeCorsten likes this.
    01-28-2016 08:24 AM
  8. LeoRex's Avatar
    They make those, too.... Samsung Elevator
    01-28-2016 08:37 AM
  9. dpham00's Avatar
    Personally I would wait to see how the s7 is, unless you are in a hurry. Prices may also drop on the note 5 once the s7 is released
    01-28-2016 08:38 AM
  10. LeoRex's Avatar
    It all depends on one simple question... "Do you need to upgrade from a S5 to a Note 5?"
    I mean, the Note 5 is, for all intents and purposes, a superior device to the S5 in near every aspect. But the 'should I upgrade" question is near impossible to answer because 99% of it is often personal choice/situation.
    01-28-2016 08:40 AM
  11. Von Spradlin's Avatar
    To bad the Samsung Elevators and Escalators are bogged down by their touchwiz push button panels. To much lag between floors if you ask me.
    01-28-2016 09:34 PM
  1. Replies: 2
    Last Post: 01-28-2016, 12:50 AM
  2. Replies: 1
    Last Post: 01-28-2016, 12:12 AM
  3. How should I make an Android app?
    By AC Question in forum Android Apps
    Last Post: 01-28-2016, 12:03 AM
  4. Should I manually update my Phone?
    Last Post: 01-27-2016, 04:19 PM
  5. Samsung j1 ace upgrade to lollipop
    By jaselorimer777 in forum Ask a Question
    Last Post: 01-27-2016, 11:41 AM
