1. AC Question's Avatar
    I have to click on the item I want to copy.it shows up on the screen,only about four times larger that the original. I have to use control- to shrink it,which shrinks all the other items on the screen I want to copy from
    01-29-2016 10:52 AM
  2. anon(632115)'s Avatar
    It would be helpful if you could tell us what you are trying to copy from and to and what your device is. There is no ctrl key on Android so I am totally confused
    01-29-2016 11:07 AM
  3. Rukbat's Avatar
    If you use Total Commander, you can copy files without seeing the picture. You just copy the entire file.
    01-29-2016 03:06 PM
  1. Notification Badges not showing up, gmail and others?
    By markm75 in forum Legacy Android & Other OS's
    Last Post: 02-04-2016, 07:46 AM
  2. Can you mirror flip you phone's layout?
    Last Post: 01-29-2016, 02:42 PM
  3. why cant I open attachments on my emails
    Last Post: 01-29-2016, 10:53 AM
  4. How do I get rid of the floating small keyboard
    Last Post: 01-29-2016, 10:29 AM
  5. Why can't I access the private box on go sms pro on my new Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 01-29-2016, 10:16 AM
