1. andrew k3's Avatar
    I have a problem with my Huawei g7 not detecting fast wireless networks, it doesn't even appear in the list of networks, yet the ordinary ones do.
    Any ideas why? I'm sure I read the phone is compatible with 802.11b, 802.11g, 802.11n
    01-30-2016 12:20 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! What do you mean by ordinary wi-fi networks? Is it able to connect to your home wi-fi network? If it's not seeing other private wi-fi networks, that may be because the owners of those networks set the router to hide the SSID.
    01-30-2016 03:09 PM
  3. andrew k3's Avatar
    Hi, thanks for the reply.
    The networks are at work. One is called Wireless442 and the other is called Wireless442fast. The latter does not appear in the list. Yet it does on other people's phones.
    01-31-2016 07:25 AM
  4. B. Diddy's Avatar
    Do you know if those work wi-fi networks are 5 GHz or 2.4 GHz? The G7 doesn't support 5 GHz.
    01-31-2016 02:30 PM
  5. andrew k3's Avatar
    Right, thank you.
    B. Diddy likes this.
    02-01-2016 01:58 PM
  6. B. Diddy's Avatar
    Was that the issue, or is it something you have to check with work?
    02-01-2016 02:09 PM
  1. Replies: 4
    Last Post: 01-30-2016, 12:31 PM
  2. I have a Huawei Raven LTE and it is froze
    By Jeremy1091 in forum Ask a Question
    Last Post: 01-30-2016, 08:36 AM
  3. Replies: 0
    Last Post: 01-30-2016, 05:49 AM
  4. Replies: 1
    Last Post: 01-30-2016, 12:10 AM
  5. WiFi hotspot off of Bluetooth Internet
    By Jarod Boyd in forum Legacy Android & Other OS's
    Last Post: 01-29-2016, 10:44 PM
