1. AC Question's Avatar
    Why does my default notification sound have to be the same as my message notification sound? I like to make them separate and every time I try my message notification will only do what default doe. it won't stick with the one I choose for messaging
    01-30-2016 02:18 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Are you changing the notification tone within the Messaging app's own menu?
    01-30-2016 02:36 PM
  1. How can I add music to my Samsung S6 Active? What is the best app to use?
    By AC Question in forum Samsung Galaxy S6 active
    Last Post: 03-23-2016, 01:23 AM
  2. Replies: 5
    Last Post: 01-30-2016, 07:45 PM
  3. Replies: 1
    Last Post: 01-30-2016, 02:42 PM
  4. I need a Facebook icon on my homepage, how can I get it?
    By AC Question in forum Android Apps
    Last Post: 01-30-2016, 02:28 PM
  5. Is the samsung gear s2 compatible with the galaxy j5
    By Bmiller123 in forum Ask a Question
    Last Post: 01-30-2016, 01:53 PM
