sd card not working in my moto x play
i use moto x play after recent marshmallow update my sd card stopped working in my mobile and in other gadgets this happened after I copied the WWE immortals obb file into another folder and the other mistake I've done is I made my sd card as internal in my mobile and now my sd card crashed and stopped working can you help me to how to fix it and I also tried to format it in my laptop it is not working.
Re: sd card not working in my moto x play
There are some things that changed after Marshmallow. Take a look at this Motorola support page.
https://motorola-global-portal.custh...34/p/1449,9582
