1. AC Question's Avatar
    i need my contacts to get imported to my device (android) from gmail......how can i do that??
    02-01-2016 10:56 PM
  2. crownybest's Avatar
    go to settings and accounts somewhere in there and enter that account in there and sync the contacts to the phone
    02-01-2016 11:35 PM
  3. bobobo3's Avatar
    Here is how to import contatcs from Gmail to Android:
    Open your “Contacts” app.
    Click the menu button and go into “Settings.”
    Select “Import/Export.”
    Select where you want your contact files stored.
    Follow instructions.
    03-21-2019 09:37 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! If you log into a new device with your Google account, your contacts that are saved to your Google account should sync automatically. (Your contacts are saved to your Google account, not to your Gmail.)
    03-23-2019 01:59 AM
  1. Question on UMX MXW1 Android phone, can I get some help?
    Last Post: 06-03-2017, 09:02 AM
  2. is it poss to get new numbr wth extra phone
    Last Post: 02-02-2016, 12:10 AM
  3. Replies: 0
    Last Post: 02-01-2016, 10:29 PM
  4. How to replace microphone icon with emojis s5
    By jeharris24 in forum Samsung Galaxy S5
    Last Post: 02-01-2016, 10:25 PM
  5. Replies: 2
    Last Post: 02-01-2016, 09:51 PM
