1. AC Question's Avatar
    When somebody texts It won't show up in my notifications Until I open the app
    02-03-2016 06:16 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Open the Messaging app, tap Menu>Settings, look for the notification options, and make sure they're turned on. If they are and you still don't see them, then go to Settings>Data Usage and make sure Restrict Background Data isn't turned on. You may need to select the Messaging app in that menu, and check to see if the individual Restrict Background Data setting for that app is turned on.
    02-04-2016 12:11 AM
  1. Why won't my S5 update after factory reset?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 05-02-2016, 04:42 PM
  2. People aren't receiving my texted pictures. What am I doing wrong?
    Last Post: 02-05-2016, 12:55 AM
  3. Why can't I play any videos from my photo gallery?
    Last Post: 02-04-2016, 12:29 AM
  4. How do you remove headphone icon from notification bar?
    Last Post: 02-04-2016, 12:27 AM
  5. Phone won't go into Recovery mode: Red ! Triangle. What can I do?
    By koam in forum Legacy Android & Other OS's
    Last Post: 02-03-2016, 06:33 PM
