1. tinker1234's Avatar
    Android 4.4 KitKat
    LG Volt
    Virgin Mobile
    In my system messages area ( swiping downward on my screen from the top ) is a button to install "Quick Remote", something to control other devices from my phone.
    I'm not interested.
    I can't find any apps under the title "Quick Remote" in settings so I can uninstall or disable it.
    How do I get rid of it?
    Thank You
    Steve
    02-05-2016 09:41 PM
  2. drderbydog's Avatar
    On my Samsung Galaxy S6 the app is called "Peel Smart Remote" under the application manager in system. I am on Verizon and could not uninstall it, but I was able to disable it.
    02-06-2016 02:23 PM
  1. Replies: 1
    Last Post: 02-06-2016, 06:04 PM
  2. galaxy 5s will not call out in areas it used to
    Last Post: 02-06-2016, 06:01 PM
  3. Replies: 1
    Last Post: 02-05-2016, 10:17 PM
  4. How to root Lenovo Vibe S1, running on os v5.0 lollipop
    Last Post: 02-05-2016, 09:22 PM
