1. AC Question's Avatar
    Under one name I have to search through 5 or 6 contacts to find the one with the number
    02-07-2016 04:57 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you know which accounts each duplicate is from? Select each contact, Edit it, and see which account it belongs to at the top of the edit screen. You might be syncing the same contacts from multiple accounts, like your Yahoo account, LinkedIn, etc.
    Go to Settings>Accounts, and check the various accounts there. Do any of them show that they're syncing contacts, besides Google?
    Crashdamage likes this.
    02-07-2016 11:44 PM
  1. Replies: 3
    Last Post: 02-23-2018, 01:06 PM
  2. What model to buy for the UK?
    By Poppy59 in forum Huawei Mate 8
    Last Post: 03-09-2016, 02:55 PM
  3. How do I move pics in my gallery from album to another?
    Last Post: 02-09-2016, 12:49 AM
  4. Usually how long till roms get updated for popular phones?
    By Advaitom in forum General Help and How To
    Last Post: 02-08-2016, 12:11 AM
  5. Why do the apps I try to download stay in install mode?
    By craiggy in forum Ask a Question
    Last Post: 02-07-2016, 07:30 PM
