1. AC Question's Avatar
    I have a android 4.2
    Whenever I download a call blocker on play google, my message notifications messes up. Any suggestions? I have to uninstall the call blockers.
    02-08-2016 08:50 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Is it the notifications that are getting messed up?
    02-08-2016 09:25 AM
  3. Rose5's Avatar
    Yes. Also, I had another app battery full notification that also messed up the message notification.
    02-08-2016 09:28 AM
  4. Golfdriver97's Avatar
    Have you tried turning off notifications for the call block app?
    02-08-2016 09:33 AM
  5. Rose5's Avatar
    No, but when I uninstall the 2 applications the notification popups worked. Now I I'm not sure what apps should I install. I don't trust that play google anymore
    02-08-2016 09:37 AM
  6. Golfdriver97's Avatar
    You had 2 installed at the same time? If so, that might have been part of the problem.
    As for apps from Play, I would suggest getting your apps from them or Amazon. Anywhere else might just be asking for trouble.
    02-08-2016 09:59 AM
  7. Rose5's Avatar
    This never happened like that before. I usually do download 2 apps or so same time. Don't know what to do
    02-08-2016 10:25 AM
  8. Golfdriver97's Avatar
    Sorry...to clarify, you had 2 call blockers? They might have been conflicting each other.
    02-08-2016 01:48 PM
  9. Rose5's Avatar
    Ok, I install another applications. Its doing it again. Though. How do I fix this?
    02-09-2016 02:27 AM
  10. Golfdriver97's Avatar
    What device do you have? It might be an error in the OEM version of Android.
    02-10-2016 07:22 PM
  11. Rose5's Avatar
    I have android 4.2
    02-11-2016 02:49 AM
  12. Rose5's Avatar
    Its all call blocker doing it. I delete it call blocker and still doing it now.
    02-11-2016 09:01 AM
  1. Replies: 24
    Last Post: 08-19-2017, 05:21 AM
  2. note3 dont hear nothing on making or receiveing call
    By speedspeed in forum Samsung Galaxy Note 3
    Last Post: 02-09-2016, 04:05 PM
  3. Authentication problem
    Last Post: 02-08-2016, 01:32 AM
  4. Problem with WiFi connectivity
    By qwery_123 in forum Sprint Galaxy Note 2
    Last Post: 02-07-2016, 11:15 PM
  5. Replies: 0
    Last Post: 02-07-2016, 10:10 PM
