A AC Question Feb 9, 2016 #1 kyocera hydro i am gedtting wi-fi calling error reg90 popping up on my cell what is that & how do i fix it
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,536 4,673 113 Visit site Feb 9, 2016 #2 Re: kyocera hydro Welcome to Android Central! Which carrier are you using? Is the phone originally from that carrier, or did you unlock it and use it on a different carrier?
