I'm running CM 12.1 on an LG G3 (VS985) with TWRP recovery.
I used an app called UI Tuner to change my resolution, thinking that it would revert back to normal after 15 seconds.. well it didn't. It crashed? when I did it, and then it started back up? with the super low resolution.
Now I'm stuck with a screen that's like 200x300 and the DPI is wayy off, so I can't really use the screen.
I used TWRP to manually delete the app, but the problem persists. The reason it doesn't just reset my resolution upon startup is because I had it set to change my resolution to 1920x1080 for better performance on startup. Is there a way to stop it from running on startup? I have access to TWRP still, and I can sorta do very limited things within my phone, but it's so small that all I can do is open apps and see the very tops of them.
I tried looking for a way to manually stop apps from running on startup, but all I can find are guides on how to use apps that you install.. which doesn't help at all.
I really would like to keep my current apps and setup and everything. I almost resorted to just flashing a new ROM, but I really don't want to do that.
I tried using ADB, but it says that there's no device found. I'm pretty sure I had USB debugging on, so I don't know why it can't find my phone... although I can't really see it to tell if it's on or not.
02-11-2016 02:51 AM
