Originally Posted by
Mooncatt Pretty much every manufacturer instructs you to unplug anything when not in use. Chargers, tv's, stereos, etc. It's part of the whole green movement, where they don't like even the small amount of power they consume when powered off.
Green movement and liability. If it's not plugged in it can't randomly start a fire or otherwise cause damage to the furniture it's on or any surrounding objects.
Love how a DVR, which is intended to automatically record, comes with the same warning. How is it supposed to record if it's not plugged in?
