1. AC Question's Avatar
    Hard reset removes everything, except password. How can I remove an apparently embedded password?
    02-14-2016 01:09 PM
  2. xocomaox's Avatar
    Hold volume up and power button until you see the RCA logo. Let go of the buttons after a couple seconds. An Android recovery screen will appear and you can select wipe data/factory reset. This will wipe the data.. If the factory image has a password pre-installed you will have to get this from the retailer who provisioned the unit.
    The only way to remove the password from the factory image is to obtain it, then flash a different firmware without a password.
    02-14-2016 01:32 PM
  1. Email sync and notifications issue
    By DreamSTi in forum Samsung Galaxy Note 5
    Last Post: 03-04-2016, 11:38 AM
  2. Replies: 75
    Last Post: 02-16-2016, 10:23 AM
  3. How to get color on photos
    Last Post: 02-14-2016, 01:18 PM
  4. Replies: 1
    Last Post: 02-14-2016, 12:49 PM
  5. My mobile data is not working.Can anybody help?
    Last Post: 02-14-2016, 12:27 PM
