1. AC Question's Avatar
    I changed my settings on my lock screen from show all to show some and now I can't find the setting to cancel this change.
    02-14-2016 02:21 PM
  2. SI0220's Avatar
    Hi.
    It's fairly simple.
    What phone are you currently using?
    Either ways-
    *if it's an older version
    1. Go to Settings
    2. Go to Sounds and Notifications.
    3. All the way the bottom go to Lock Screen Notifications
    4. There you'll see options to choose from
    *if it's the newest update
    1. Go to settings
    2. Go to Lock Screen and Security
    3. Go to Notifications
    4. There are your optuons.
    Hope this helps
    02-14-2016 02:49 PM
  1. Android Central Article Comments How-To
    By epic_user in forum Site Feedback & Help
    Last Post: 02-17-2016, 11:33 AM
  2. What do the different colours of the contacts' icons mean?
    Last Post: 02-14-2016, 04:08 PM
  3. Replies: 1
    Last Post: 02-14-2016, 01:43 PM
  4. Replies: 1
    Last Post: 02-14-2016, 01:34 PM
  5. Why has sound setting stopped?
    Last Post: 02-14-2016, 01:22 PM
