1. AC Question's Avatar
    when we open the browser it gets over run with popups, we can't get to the settings to block the pop ups because it is over run. is there a solution?
    02-16-2016 10:53 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Tap the Home button to get back to the homescreen, then go to your system settings. Go to Settings>Apps>All​, select your browser, and Clear Cache/Clear Data, then Force Stop. Now open the browser again and see if the problem persists.
    02-17-2016 01:56 AM
  1. Where is google search bar
    Last Post: 02-16-2016, 10:54 PM
  2. Replies: 1
    Last Post: 02-16-2016, 10:21 PM
  3. Replies: 1
    Last Post: 02-16-2016, 10:14 PM
