I had to do a factory reset, thereby loosing all my SMS messages on the Droid. I did back them up to gmail using SMS Backup. Is there any way to restore them to the phone?
I don't think SMS Backup has a restore option. There are however, other apps out there that will backup/restore.
didn't even know there was as "sms backup" option, good info there.
Question: without restore capabilities, what good is the backup? can you just read them on your PC, or what?
