1. merriwarren's Avatar
    When unlocking the phone, the talk back feature says the pin code out loud as its being typed. Is there a setting to turn this off (only for unlocking the phone - talk back needs to stay on)?
    02-28-2016 06:46 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you're not encrypted, one workaround would be to use pattern unlock, rather than PIN or password.
    02-28-2016 07:02 PM
  3. merriwarren's Avatar
    Thanks for your suggestion! Unfortunately I am blind, so using a pattern will be very difficult for me. Is there any other solutions you can think of?
    03-03-2016 05:59 PM
  4. B. Diddy's Avatar
    Just curious--if you're blind, how are you able to tap the correct PIN without TalkBack? Is your vision just good enough to discern where the numbers are?
    03-04-2016 09:59 PM
  5. merriwarren's Avatar
    I am legally blind, however my vision is good enough to see things right in front of my face. The keyboard is difficult to see for a passcode, but the num pad is simple enough for me.
    03-09-2016 06:14 PM
  1. Replies: 4
    Last Post: 08-09-2016, 02:07 PM
  2. Replies: 6
    Last Post: 03-29-2016, 04:02 PM
  3. Actual storage space on new Note 5 32GB?
    By AmyNo in forum Samsung Galaxy Note 5
    Last Post: 02-29-2016, 06:50 AM
  4. Replies: 2
    Last Post: 02-29-2016, 03:31 AM
  5. Replies: 0
    Last Post: 02-28-2016, 06:43 PM
