1. bodwyn's Avatar
    I installed Battery Doctor.
    After a couple of days, I conceded to let it manage the lock screen PIN so I didn't hve to swipe twice to enter it.
    BDr then sid I'm entering the wrong PIN.
    I reset the main phone PIN using google device manager, so now I get the normal lock screen, I enter the PIN, then the BDr lock screen appears.
    I can briefly see the home screen between actions of the BDr lock screen (it lets you see battery, weather, you can open a calcultor), but I haven't found a way to sneak past BDr lock screen, but that may indicate to someone the nature of its lock screen.
    I downloaded ADB.exe by xda developers to try to remove BDr but can't figure out how, if you have any tips.
    I want to avoid a factory reset as I don't want to lose data, photos on the phone (Archos 55 platinum).
    02-28-2016 10:52 PM
  2. Denny P2's Avatar
    Connect your phone with PC. Open a command prompt in the window where your ADB.exe is and type this commands one by one:
    Code:
    adb.exe shell
    cd \data\app\
    rm com.ijinshan.kbatterydoctor.apk
    I wrote this assuming the app name in the phone is com.ijinshan.kbatterydoctor. If you ran in to any problems just ask.
    02-29-2016 12:08 AM
  1. U.S. Cellular model only has 3GB of RAM!!!
    By ironass in forum Samsung Galaxy S7 edge
    Last Post: 03-30-2016, 07:36 AM
  2. Replies: 1
    Last Post: 02-29-2016, 04:24 PM
  3. Replies: 1
    Last Post: 02-29-2016, 04:14 PM
  4. How much can I sell my Galaxy S6 for?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 02-29-2016, 07:48 AM
  5. U.S. Cellular model only has 3GB of RAM!!!
    Last Post: 02-28-2016, 10:50 PM
