1. rp17's Avatar
    I've gone through all my starred contacts, most of whom have more than one contact number, and set the "default" number for each one. However, if I use the Okay Google voice command to call or text one of those contacts, it still asks me at which number every single time. Is there a way to make it use the default number, or to tell it to always use the same number after it makes me choose the first time?
    02-29-2016 11:01 AM
  2. N4Newbie's Avatar
    Nope, not that I am aware of.
    However, you can say,
    "OK Google ... call John Smith on mobile"
    "OK Google ... call Mom on home"
    and so on
    02-29-2016 11:38 AM
  3. rp17's Avatar
    Thanks! Too bad it ignores the default numbers, but good to know there's a workaround.
    02-29-2016 12:23 PM
  1. Replies: 3
    Last Post: 03-01-2016, 01:42 AM
  2. Samsung Tab 2, 10.1 fails to reload after hard reset, what should I do?
    By AC Question in forum Samsung Galaxy Tab 2 10.1
    Last Post: 02-29-2016, 12:12 PM
  3. how to reinstall the preinstalled apps?
    By AC Question in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 02-29-2016, 12:11 PM
  4. Why is neither phone memory or SD storage showing?
    By AC Question in forum Memory (RAM)
    Last Post: 02-29-2016, 10:19 AM
  5. Replies: 0
    Last Post: 02-29-2016, 10:11 AM
