1. ColoFirefighter's Avatar
    I am now using a T-Mobile GS-7 Edge. I have had this issue on two GS-6 and a GS-5. This is my third operating system. On kitkat I was fine, on lollipop the issue started and stayed up to current day. An application is causing my apps not to auto update even though I have all of my setting to auto update. They will sit in a "pending" status. I can watch my battery draining and feel my phone heat up until I go in and force update my apps in the play store. I can't figure out which app is causing the issue. I've removed all of my old apps. Is there a diagnostic tool or someone out there that can help? Google tech support, T-Mobile store associates and phone tech support cannot figure out what is causing this. I'm despite and about to switch to Apple.
    03-01-2016 03:07 PM
  2. sydneycooper1979's Avatar
    I had a similar problem with my google account syncing chrome. I would suggest clearing the cache partition on your phone or going into the main settings menu>applications>clear data. Is every app in a pending state or just a few?
    Laura Knotek likes this.
    03-01-2016 05:44 PM
  3. ColoFirefighter's Avatar
    I've done that. It is basically any and every app in the play store. Whenever an app tries to update it doesn't. It drains my battery and sits. I have to hit update all or update each individual app to force the update.
    03-01-2016 06:32 PM
  4. belodion's Avatar
    Does the problem persist in Safe Mode?
    03-01-2016 08:52 PM
  5. ColoFirefighter's Avatar
    No. That is why I believe it is an app. I can't for the life of me figure out which one.
    03-01-2016 09:05 PM
  6. ColoFirefighter's Avatar
    Any other help would be nice. I don't want to switch to Apple but might if I can't figure this out.
    03-03-2016 08:33 AM
  7. ColoFirefighter's Avatar
    Bump
    03-03-2016 04:35 PM
  8. Javier P's Avatar
    It's quite difficult to know for sure which app is causing this issue. I will start for the usual suspects, task killers, battery savers, antivirus... Do you have any app checked in settings - security - device administrators?
    03-03-2016 04:46 PM
  9. ColoFirefighter's Avatar
    I don't have any third party apps for task killers or Antivirus. I have the stock premium Lookout and the app optimization Samsung preloads. This is what the device admin has.
    03-03-2016 06:04 PM
  10. Javier P's Avatar
    Nothing there. Does it happen when you're using mobile data, WiFi or both? What option do you have selected in the Play Store for auto update? Does it make a difference if you select to update over WiFi only? Have you installed any connection optimiser or a similar app for WiFi or mobile?
    This is a strange problem and I've never seen it reported before so excuse all the questions. I'm just trying to narrow the search.
    03-03-2016 07:30 PM
  11. ColoFirefighter's Avatar
    Here are my screen shots
    03-03-2016 08:10 PM
  12. ColoFirefighter's Avatar
    I tried posting a bunch of screen shots. Wifi on either setting will not download.
    03-03-2016 08:22 PM
  13. ColoFirefighter's Avatar
    03-03-2016 10:47 PM
  14. ColoFirefighter's Avatar
    03-03-2016 10:48 PM
  15. ColoFirefighter's Avatar
    03-03-2016 10:48 PM
  16. ColoFirefighter's Avatar
    3
    03-03-2016 10:48 PM
  17. ColoFirefighter's Avatar
    4
    03-03-2016 10:49 PM
  18. ColoFirefighter's Avatar
    5
    03-03-2016 10:49 PM
  19. ColoFirefighter's Avatar
    6
    03-03-2016 10:50 PM
  20. Javier P's Avatar
    I feel I'm missing something here. There are some things that make your problem very strange. It passes from phone to phone, everything is fine in safe mode and your battery drains trying to auto update on the Play Store. This combination makes some of the usual fixes useless, including factory reset.
    Have you managed to see in your battery stats which apps are high on the list when this drain happens? That could give you some clues.
    I think that Lookout keeps running even in safe mode, but you could try disabling it temporarily and see if the problem persists. I can't think of many apps that could interfere with the auto update.
    Some Play Store issues get fixed after resetting app preferences in settings - apps - overflow menu top right. Worth a try. Also, select any of those apps that didn't update and tap on the three dots top right to make sure the "don't auto update" box is unchecked.
    Another thing. Do you have more than one Google account in your phone?
    03-04-2016 04:45 PM
  21. ColoFirefighter's Avatar
    I do have more than one Google account on my phone
    03-14-2016 03:51 PM
  1. How can I connect a NOTE 5 to a Pioneer App Radio Model is SPH-DA120?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 09-20-2016, 11:34 AM
  2. Galaxy S7 Edge - early issues thread
    By toptekjon in forum Samsung Galaxy S7 edge
    Last Post: 06-07-2016, 01:50 PM
  3. Help with sm-g360f lte rooting?
    By AC Question in forum Samsung Galaxy Core Prime
    Last Post: 03-11-2016, 04:46 PM
  4. Navigation app - custom routes
    By gjkiii in forum Android Apps
    Last Post: 03-02-2016, 02:57 PM
  5. Why is it when I get within wifi range my Note 3 opens ALL APPS?
    By Kent Maynard in forum Samsung Galaxy Note 3
    Last Post: 03-01-2016, 12:44 PM
