1. AC Question's Avatar
    I've recently removed some apps from my phone to save on data. However, now when I click on data usage Removed Apps is now the one that's at a full bar! How do I delete that or delete the files in it? Please help!
    03-01-2016 03:29 PM
  2. Javier P's Avatar
    Hi, welcome to the forums! That information shows the data used by all those apps combined before they were disabled or uninstalled. You don't need to worry, they are not using data anymore.
    03-01-2016 03:34 PM
  1. How can I connect a NOTE 5 to a Pioneer App Radio Model is SPH-DA120?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 09-20-2016, 11:34 AM
  2. Need battery draining app issue help?
    By ColoFirefighter in forum General Help and How To
    Last Post: 03-14-2016, 03:51 PM
  3. Help with sm-g360f lte rooting?
    By AC Question in forum Samsung Galaxy Core Prime
    Last Post: 03-11-2016, 04:46 PM
  4. Navigation app - custom routes
    By gjkiii in forum Android Apps
    Last Post: 03-02-2016, 02:57 PM
  5. Why is it when I get within wifi range my Note 3 opens ALL APPS?
    By Kent Maynard in forum Samsung Galaxy Note 3
    Last Post: 03-01-2016, 12:44 PM
