1. artscience84's Avatar
    Hey all!
    I'm on a Galaxy S5 and recently paired my DualShock 4 controller to play FIFA 16.
    Due to key mapping issues, it didn't work out.
    The problem now, is that the floating buttons in FIFA have not reappeared and I have no touch response on the screen.
    I have reset the control to "Floating Buttons" in FIFA.
    I have even unpaired my device.
    Still no luck.
    The app is over 1 gig so I don't want to reinstall unless I have to.
    Is this just an app issue or a phone issue?
    Thanks if you can help.
    Cheers.
    03-01-2016 10:05 PM
  2. itguyjax8430's Avatar
    Hey all!
    Still no luck.
    Cheers.
    Welcome to Android Central!
    It could be the app bugging out, you can reset the app with out uninstalling it. You will lose your game data just FYI. You can go to your settings, apps, all apps, find the game in the list and clear the data from it. That should reset the game and may fix the issue.
    03-07-2016 07:35 AM
  1. Changing night clock to display on the left edge
    By bhatech in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 08:47 AM
  2. Replies: 2
    Last Post: 03-04-2016, 08:09 AM
  3. Upgrading from the S5 to the S7 Edge
    By RJLOMMD in forum Samsung Galaxy S7 edge
    Last Post: 03-02-2016, 03:08 PM
  4. How to remove com.andoid.play?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-01-2016, 09:29 PM
  5. Why can't I seem to delete one of my Gmail accounts?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 03-01-2016, 09:16 PM
