This app ( Touchwiz) is cause some problem to my mobile
Printable View
Welcome to Android Central! Which Samsung phone do you have? TouchWiz is the launcher, which is the entire homescreen and menu interface, so you can't uninstall that. You can install an alternate launcher like Nova Launcher. I'd also see if the problem persists in Safe Mode, and also try wiping the cache partition, but it'd help to know which phone you have first.
