I have a Huawei G7. A few months back i had rooted it because i had to backup some lost photos, and after that i unrooted it again. After that, the problems began. I can't access my settings. It just says "Unfortunately, com.android.settings has stopped". If I try to turn on my WiFi, it doesn't open and it gives the same message. So, I'm able to connect only to the networks I had connected to earlier, because it does it automatically. I tried to do a factory reset, but it was still on 0% after I had left it for 2 hours.
Anyone can help? I'd be very grateful.
03-02-2016 02:38 PM
