1. Marvven Baccouch's Avatar
    i have a lg verizon transpyer vs810pp locked to verizon wierless, i want to unlock it to use other sim card on it, i rooted it using "kingo root" but i don't know what i supposed to do? and if i want to use a code on dial pad like *#06# does't show my the IMEI ( i can find the IMEI in setting/about phone/status), but why does't show my the IMEI when i type *#06# on dial pad? i want to sell the phone but i should unlock it first please help me . and one more thing,,,,, if i unlock the phone, is it lock again when i do "factory reset"??? ////////////// thanks!!!!!!!!
    03-11-2016 04:20 AM
  2. hallux's Avatar
    The "problem" with older Verizon devices is that they just didn't contain the radios needed for other networks. Looking at the specs, you likely will not be able to go to other networks with your phone.
    BTW, root isn't needed to SIM-unlock a device.
    Marvven Baccouch likes this.
    03-11-2016 05:03 AM
  3. Marvven Baccouch's Avatar
    Does this mean that there is no solution, and what is ;radio for other networks is that a hardware or software
    03-11-2016 05:42 AM
  4. hallux's Avatar
    It's actually hardware. Yes, it means that the device just will not work with another carrier. Many newer devices contain the hardware needed to connect to those other networks.
    03-11-2016 06:13 AM
  5. Marvven Baccouch's Avatar
    Do you mean that I can not do anything and there is no solution;;;;;;;( please help me)
    03-11-2016 06:28 AM
  6. hallux's Avatar
    Here are the specs for the phone: LG Transpyre specs
    Under the technology section, the frequencies are Verizon frequencies/technologies, nothing else. The phone would need to support frequencies for other carriers in order for it to work on them. It's a hardware limitation, sorry to break it to you.
    Unfortunately, this happens with older, inexpensive devices.
    03-11-2016 06:40 AM
  7. Marvven Baccouch's Avatar
    that's bad, i think verizon is the winner hhhh.
    thank you
    03-11-2016 06:56 AM
  8. Marvven Baccouch's Avatar
    you don't tell me why *#06# do nothing
    03-11-2016 07:12 AM
  9. hallux's Avatar
    I don't know anything about the dialer codes like that. Sorry.
    03-11-2016 07:22 AM
  1. What are Top Android Apps to used by many users?
    By AC Question in forum Android Apps
    Last Post: 03-18-2016, 04:18 PM
  2. How can I get my phone to turn back on?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 03-11-2016, 07:57 AM
  3. Will a Samsung 32gb class10 SD card work OK?
    By DannyHeard in forum Samsung Galaxy S4
    Last Post: 03-11-2016, 03:29 AM
  4. How to fix my phone when it is stuck?
    Last Post: 03-11-2016, 03:14 AM
  5. Replies: 0
    Last Post: 03-11-2016, 02:45 AM
