1. gmoproA's Avatar
    So after the latest Android update...when i try to share a webpage or to others, the result is a little different than before...
    It now has a top part that shows contacts so you can directly share to them instead of choosing the app and then the contact within that. So the problem is that it doesnt show the contact faces every time, just their phone numbers. Then when i try it again, it sometimes pulls in the faces of the contacts. So it is inconsistent and that is not a fun experience. This needs some work here. It isnt working properly. So the share function needs to be examined and fixed. Shouldve been tested thoroughly before release.
    My phone is HTC one m8.
    03-11-2016 10:03 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Have you tried booting in to recovery and wiping the cache partition?
    https://support.t-mobile.com/docs/DOC-10672
    03-15-2016 09:01 AM
  3. gmoproA's Avatar
    Nah, thanks though. Hoping it gets corrected though at least for the next update.
    04-14-2016 07:56 PM
  1. How do I disable swipe to unlock when I have pattern unlock?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-07-2018, 09:52 PM
  2. More ways to save....
    By Golfdriver97 in forum Legacy Android & Other OS's
    Last Post: 03-11-2016, 03:52 PM
  3. What cards to you think Google's holding?
    By LeoRex in forum Legacy Android & Other OS's
    Last Post: 03-11-2016, 03:04 PM
  4. New Update to SP-Ver. 1.7.04
    By jexx in forum Android Apps
    Last Post: 03-11-2016, 02:46 PM
  5. How do I empty the Gmail trash on my Android tablet?
    By AC Question in forum Misc. Android Tablets
    Last Post: 03-11-2016, 09:47 AM
