1. Dudley99's Avatar
    Please, please, please help me. Anyone!
    For the past two days, I've noticed my battery has drained exceptionally quickly. I have no idea why - I'm not on it much at all, don't make many calls at all, etc. It never dies at school, but for the past three days it has.
    This morning, I unplugged it from fully charging all night, played 5 words on "Words with Friends," and browsed a message board for about fifteen minutes. By 10:45 that morning, my phone died due to no battery.
    Luckily, I brought my charger, and when I got around to turning it back on, I got a message from my carrier about my data usage. They say I have used >5 gigabytes in not even four days! I have unlimited data, but they say that my data speed will be reduced for the rest of the month due to my data usage.
    After going to a physical store (no help at all), calling my carrier (no help at all) and being transferred to android support, all I learned is what I already knew - somehow an insane amount of data is being used by my phone. He said to check back next month and that there was nothing they could do, unless they sent the phone to "engineers."
    I don't tether (to my knowledge?) and am hardly ever on my phone. An employee at my carrier's store suggested that I am using a lot of data because I have the phone "synced" with my Gmail and Facebook account. Please!
    Any help? Here is a breakdown, sorry for the size. But look at the numbers!
    Data: 5.0989 GB / Unlimited
    Service Used Included Remaining Charges
    Data 5.0989 GB Unlimited Unlimited $0.00
    * Usage for active or recently ended calls or data sessions may not be displayed. For billing, data is rounded up to the nearest MB.
    All recent activity
    In Network
    Date Time Megabytes
    03/04/11 10:08 AM 44.1367
    03/04/11 08:47 AM 260.0478
    03/04/11 08:43 AM 15.0009
    03/04/11 08:41 AM 10.0009
    03/04/11 06:43 AM 300.0009
    03/04/11 05:42 AM 30.0664
    03/04/11 04:24 AM 6.6875
    03/04/11 03:08 AM 168.4541
    03/04/11 01:08 AM 360
    03/03/11 11:09 PM 290.0009
    03/03/11 09:35 PM 7.1787
    03/03/11 09:18 PM 40.0009
    03/03/11 07:41 PM 168.205
    03/03/11 07:37 PM 15.0009
    03/03/11 07:34 PM 15.0009
    03/03/11 05:40 PM 350.0009
    03/03/11 05:22 PM 0.0058
    03/03/11 04:42 PM 37.8867
    03/03/11 04:15 PM 0.0009
    03/03/11 04:13 PM 0.0048
    03/03/11 03:11 PM 12.6621
    03/03/11 01:36 PM 227.5566
    03/03/11 11:38 AM 323.6103
    03/03/11 10:09 AM 224.6142
    03/03/11 08:15 AM 260.0009
    03/03/11 06:37 AM 100.8076
    03/03/11 05:53 AM 73.8564
    03/03/11 05:51 AM 10
    03/03/11 05:48 AM 10.0009
    03/03/11 03:49 AM 380
    03/03/11 01:48 AM 360.0019
    03/02/11 11:46 PM 400
    03/02/11 09:41 PM 355.0009
    03/02/11 08:58 PM 0.0185
    03/02/11 07:28 PM 0.0058
    03/02/11 05:33 PM 86.8847
    03/02/11 05:09 PM 6.1318
    03/02/11 05:07 PM 5.0019
    03/02/11 04:02 PM 192.7695
    03/02/11 03:52 PM 0.0166
    03/02/11 03:04 PM 8.8027
    03/02/11 02:13 PM 10.2041
    03/02/11 11:52 AM 4.0722
    03/02/11 09:52 AM 4.371
    03/02/11 08:19 AM 3.3984
    03/02/11 06:19 AM 5.3388
    03/02/11 05:21 AM 1.8222
    03/02/11 03:21 AM 0.0019
    03/02/11 01:21 AM 0.0019
    03/01/11 11:21 PM 0.0019
    03/01/11 09:21 PM 7.8496
    03/01/11 08:11 PM 9.6269
    03/01/11 06:16 PM 9.5722
    03/01/11 04:32 PM 6.1015
    03/01/11 02:32 PM 0.0585
    03/01/11 12:32 PM 7.2138
    03/01/11 10:32 AM 6.1767
    03/01/11 09:13 AM 9.6103
    03/01/11 07:13 AM 8.8681
    03/01/11 05:36 AM 9.6533
    03/01/11 04:26 AM 0.0009
    03/01/11 02:26 AM 0.0019
    03/01/11 12:24 AM 0.0019
    Total Megabytes 5,259.373
    03-05-2011 11:00 AM
  2. deferom's Avatar
    Are there any applications you have installed recently? Try uninstalling those, they may be the culprit.
    Sent from my HTC EVO 4G.
    03-05-2011 11:07 AM
  3. Dudley99's Avatar
    Thank you for the reply, I really appreciate it. I've tried thinking, but I don't believe I've downloaded any apps at all during the past three days (which is when the insane amount of data seems to have started). Because my battery was running low (and before I noticed the data usage), I started deleting some things from my phone to see if it'd help, but I can't remember all of them.
    Here is what is on my phone now (besides the preloaded apps):
    Advanced Task Killer Free
    Amazon Kindle
    Facebook
    Market
    Music Online Lite
    Newton Lite
    Pandora
    ScoreCenter
    Shazam
    Unblock Me Free
    Wikidroid
    I remember deleting a few apps a couple of days ago, including:
    Slice It
    Pic Say
    (Some other random photo editing program)
    (Some other scrabble-like android game)
    Words with Friends (bc I heard you needed to update to the newer version in order to conserve battery life, etc.)
    X Construct
    I'm sure there were others also.
    I know there was a photo editing program that was recently found to be included in the malicious apps, but it had been on my phone for a while and I've never noticed any problems.
    Again, thanks for the help. Is there any other advice anyone else has? I am at a total loss...
    03-05-2011 11:28 AM
  4. ls377's Avatar
    If it was in the malicious apps, just deleting it doesn't help. You have to completely factory reset the phone.
    I have a feeling that is the cause of it. That's a scary amount of data, especially since it looks like you're using more data at one time than I use in an entire month.
    What phone do you have?
    03-05-2011 12:44 PM
  5. greydarrah's Avatar
    I would definitely do a factory reset. Sounds like something has highjacked your phone.
    Edit:
    If you haven't done a battery pull yet, I'd try that. Maybe you just have an app that's gotten in crazy way and can't shut itself down. Otherwise...factory reset.
    03-05-2011 01:40 PM
  6. ls377's Avatar
    Edit:
    I wouldn't bet on that, no app should be using that much data, even if they go crazy.
    OP: You're probably going to need to do Odin/ruu/sbf on your phone to wipe it out.
    03-05-2011 02:30 PM
  7. Dudley99's Avatar
    I know! The most I've ever used in a month is ~800 mb. Something is definitely not right.
    I have a Samsung Galaxy S Vibrant.
    03-05-2011 04:32 PM
  8. Dudley99's Avatar
    @ grey and ls377
    Thanks a lot. I'll try this.
    I'm not sure what "Odin/ruu/sbf" is, but i have google.
    I hope this gets resolved.
    03-05-2011 04:34 PM
  9. ls377's Avatar
    Odin is what you need for a Samsung phone. I don't know if the Vibrant has a one-click option, but if so it's incredibly easy.
    03-05-2011 06:15 PM
  10. Dudley99's Avatar
    Is odin the same thing as rooting?
    I'm sorry, I'm relatively new to all of this. I had an old nokia for forever.
    Once I figure out what odin is and install? it, what then?
    Oh and thanks again!
    03-05-2011 07:45 PM
  11. ls377's Avatar
    Odin isn't rooting, although it does technically modify your phone. Afterwards, you'll have a fresh out of the box (software wise) Vibrant. If this scares you, you can try to bring it in the the carrier store and tell them what's happening, and see if they'll replace it, but this is the easiest method (and there's always the chance that the rep won't know what they're doing and just reset it through the settings).
    You'll need the files to go in the right spots. There are a few files floating around, but I'm not sure which one is the official build. I'll do some research and get back to you.
    03-05-2011 07:56 PM
  12. Dudley99's Avatar
    ^ This doesn't scare me at all.
    Thank you for looking into this for me, you have no idea how much I appreciate it!
    03-05-2011 10:30 PM
  13. ls377's Avatar
    Ok, these all should be the right files.
    If anything bad happens (very unlikely, just putting this just in case), take it to T-mobile and play dumb. They should replace it or find a way to fix it.
    Use the directions HERE except:
    Replace that Odin with THIS. It's the .exe file inside the zip. Ignore the PIT.
    Replace that Vibrant image with THIS.
    Don't use the PIT.
    03-05-2011 11:29 PM
