1. AC Question's Avatar
    When not plugged in, all I get is a flashing light. When I am charging, it shows my battery at 0% for about 10 seconds. Cuts to black for a few seconds, then shows me the blue Motorola icon with android at the bottom for another 10 seconds, with a buzz in the middle. this happens on loop. Holding down power does nothing. holding down power + volume buttons does something, where the screen goes black as long as I'm holding it down, but does nothing. Not sure how to fix this.
    03-16-2016 03:35 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which Motorola phone? Have you tried leaving it charging on a wall outlet overnight, undisturbed?
    03-16-2016 06:08 PM
  1. Replies: 0
    Last Post: 03-16-2016, 02:39 PM
  2. Replies: 0
    Last Post: 03-16-2016, 01:34 PM
  3. Why won't my phone charge?
    Last Post: 03-16-2016, 01:18 PM
  4. Screen does not stay lit - How can I set it to stay lit longer?
  5. Replies: 0
    Last Post: 03-16-2016, 01:08 PM
