1. AC Question's Avatar
    A friend brought a nokia lumia 635 for me to help him unlock it and he doesn't know which network the phone is locked to. How can I find out which network the phone is locked to.
    03-16-2016 07:46 PM
  2. RumoredNow's Avatar
    Go to this site and put in the IMEI... You will get a reading that should help.
    https://swappa.com/esn?ref=mobilenat...cUvbUpU5066463
    However, it may come back as AT&T... That could be ATT/GoPhone/Cricket... It will report all the same as ATT.
    Be advised Cricket locks their stuff tighter than anyone.
    Is there no branding on the outside? Any carrier Apps in the all App list?
    You could do a factory reset and see what carrier Apps are in the ROM as they may have been deleted after the last reset.
    Really you should be at our sister site that does Windows Phone, Ask Anything - Windows Central Forums
    I just happen to have wandered in from over there.
    03-16-2016 10:51 PM
  1. My Nexus 7 does not have a option to select WiFi under settings. Why?
    By AC Question in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-17-2016, 05:16 PM
  2. Replies: 1
    Last Post: 03-16-2016, 08:30 PM
  3. Silver Edge speaker blown straight out of box
    By paulphilly in forum Samsung Galaxy S7 edge
  4. Deleted Icon pack is not fully deleted.
    By crammpa in forum Ask a Question
    Last Post: 03-16-2016, 08:27 PM
  5. Replies: 1
    Last Post: 03-16-2016, 08:19 PM
