1. AC Question's Avatar
    When I plug a straight auxiliary cord into my headphone jack it won't recognize it. It will if it's headphones, but I like to listen while in the car. I've tried finding the solution somewhere in the settings but I can't find it
    03-16-2016 10:52 PM
  2. chennaite's Avatar
    What mobile you been using ?? Have you tried the cord with some other phone? or have you tried any other AUX cable?
    03-17-2016 03:18 AM
  3. AlphaTango414's Avatar
    First try a different AUX cable. If it still doesn't work, try using a different phone with the same AUX cable. If it works, then we have more work to do. If it doesn't work, then it seems your problem lies with your car's radio.
    03-17-2016 03:53 AM
  1. Email Address not in my Contacts
    By mushie143 in forum Verizon Samsung Galaxy S4
    Last Post: 03-18-2016, 08:20 AM
  2. Replies: 3
    Last Post: 03-18-2016, 07:33 AM
  3. Why do my apps randomly close?
    By Nathan R1 in forum Samsung Galaxy Note 3
    Last Post: 03-17-2016, 04:51 PM
  4. Replies: 1
    Last Post: 03-17-2016, 03:59 PM
  5. Replies: 1
    Last Post: 03-17-2016, 03:42 PM
