1. Mooserman15's Avatar
    I have a Samsung Galaxy Tab 2 10.1 Wi-Fi gt-p5113, currently running rooted 4.2.2 with Clockworkmod 6.0.2.3. I wanted CyanogenMod, but the latest NIGHTLY for the p5113 was ICS or something, and the latest for the p5110 was, I believe, 4.3. So, CyanogenMod is NOT the answer. I need a ROM running Lollipop or Marshmallow. Aditionally, I have the following requirements:
    1. Needs to be for the p5113, NOT THE P5110
    2. A stable build. I do not have a PC, this tablet is my computer. I need it for daily use.
    3. Support for the MicroSD, and preferably the IR port. IR NOT REQUIRED.
    While you are here, can you please answer these relevant side questions?
    1. I have CWM 6.0.2.3. Where can I get CWM 6.0.4.5 that I can flash without a PC? I prefer Philz Touch, if available. I will flash the unofficial if confirmed safe. Again, NOTHING FOR THE P5110, I HAVE A P5113.
    2. Do I need to unlock my bootloader? If so, how is that done?
    3. Do I wipe my device before or after installing the ROM?
    Thanks!
    03-17-2016 01:23 AM
  2. chrisgreencoza's Avatar
    I believe you have tried XDA Developers?
    03-17-2016 03:39 AM
  3. Mooserman15's Avatar
    I should try XDA. They will be expecting something like this.
    03-17-2016 09:18 PM
  1. Best way to mirror this phone to a TV
    By dman76 in forum Samsung Galaxy S7 edge
    Last Post: 04-05-2016, 08:27 PM
  2. Replies: 5
    Last Post: 03-17-2016, 11:34 PM
  3. Replies: 3
    Last Post: 03-17-2016, 09:10 PM
  4. Replies: 1
    Last Post: 03-17-2016, 10:51 AM
  5. Is the s7edge compatibility to I phone 6
    Last Post: 03-17-2016, 04:21 AM
