1. bjw22's Avatar
    G'day everyone,
    I need to backup some messages so that I can transfer them to a new phone in the future. I don't care where they are, as long as they are somewhere (e.g SD card, SIM etc).
    The problem is, the phone is an ancient, potato-like Samsung Galaxy Ace that runs Android 2.5. It also uses Kies 1, which has no way to backup SMS.
    A bit of help would be appreciated.
    Thanks in advance,
    03-19-2016 07:17 PM
  2. anon(632115)'s Avatar
    Try Helium on the app store
    bjw22 likes this.
    03-19-2016 08:12 PM
  3. bjw22's Avatar
    Thank you. I looked at Helium and while it was incompatible with the phone, I used it to find a similar app that was compatible that also did the job perfectly.
    Thanks mate.
    anon(632115) likes this.
    03-20-2016 03:14 PM
  1. Replies: 5
    Last Post: 09-06-2016, 06:35 AM
  2. Found a great way to send uncompressed pictures and large video files!
    By jpdaballa in forum Samsung Galaxy S7 edge
    Last Post: 06-09-2016, 04:51 AM
  3. Can't be online while on the phone
    By dadathepanda in forum Samsung Galaxy S7
    Last Post: 03-22-2016, 05:43 PM
  4. Samsung SM-n9000 LTE or not
    Last Post: 03-19-2016, 07:33 PM
  5. Replies: 0
    Last Post: 03-19-2016, 06:33 PM
