1. nabay98's Avatar
    I bought the Moto X Pure with 16 GB and I decided to add a 32 gb micro sd card. I formatted it as internal storage and went to settings > storage and usb > internal storage. I pressed the 3 dot menu in the upper right corner to migrate data to my sd card. Around midway through the process i got a notification saying there was not enough storage. Now my phone is telling me that I've used 9.52 gb out of 9.61 gb internal memory used. It seems as if 6 gb were erased. Before I did this I had plenty of data left. My phone is also telling me that I cant even receive sms messages anymore and certain system functions wont work. Even basic stuff like the camera app have been removed. Can someone please help me?
    03-19-2016 10:18 PM
  2. Golfdriver97's Avatar
    Haven't heard of anything like this yet. Have you tried a cache clear in settings?
    srkmagnus likes this.
    03-19-2016 11:22 PM
  3. nabay98's Avatar
    Yeah i have
    03-19-2016 11:44 PM
  4. srkmagnus's Avatar
    I would suggest a factory reset and see if that restored the memory. Be sure to backup what data you have before the reset. Let us know how that goes.
    03-20-2016 02:43 AM
  5. nabay98's Avatar
    It appears that I have fixed it somehow. I migrated my data from the internal storage to the sd card, but that didn't help. Then I migrated it back to the internal memory and it still didn't fix it. But then I migrated the data AGAIN to the sd card and it seems to have worked. My camera app is back which is good. A couple of nonessential apps were removed, but other than that i believe I fixed it. Weird I've never had anything like this happen before.
    03-21-2016 12:02 AM
  1. Replies: 4
    Last Post: 04-21-2016, 05:26 PM
  2. I'm having some issue and would love some help.
    By D3RP in forum Samsung Galaxy S7
    Last Post: 03-20-2016, 12:52 AM
  3. HELP with editing and importing Slow motion video on s7
    Last Post: 03-19-2016, 11:54 PM
  4. remotely turn on wifi on lost tablet
    Last Post: 03-19-2016, 11:39 PM
  5. Replies: 0
    Last Post: 03-19-2016, 09:13 PM
