I do quite a bit of writing, which I keep in long MS Word documents. I need to keep these documents synced between my Android phone and Windows. The catch is that I make heavy use of comments to review my writing and navigate through it.
Google Drive will only open documents in Google Docs, which doesn't support comments at all. MS Word for Android does sync to OneDrive, and does support comments up to a point, however the comments aren't displayed properly (you have to press on each one to view it), which makes it useless for my purposes. WPS Office for Android is a great app to use, and supports comments exactly how I want to use them, but it doesn't sync to any cloud storage, meaning that I have to share each edited document to the cloud as if it is a new document, which can only end in disaster.
Is there any way I can sync my Word documents from Android to other devices while still being able to work with a word processing app that fully supports comments?
