What does syncing do?
A
AC Question
What does synching do
I just want the definition of synching
Jerry Hildenbrand
Space Cowboy
Staff member
Oct 11, 2009
5,569
2,797
113
Re: What does synching do
Synchronization (in computer terms) means that you have two files in different locations that are kept exactly the same.
You do something on your phone. It connects to a server in the cloud. It copies the file from your phone to that server so that they are both the same. It also works in reverse and you can copy a file FROM the server to your phone.
guylenn49
