1. AC Question's Avatar
    I just want the definition of synching
    03-21-2016 07:48 PM
  2. Jerry Hildenbrand's Avatar
    Synchronization (in computer terms) means that you have two files in different locations that are kept exactly the same.
    You do something on your phone. It connects to a server in the cloud. It copies the file from your phone to that server so that they are both the same. It also works in reverse and you can copy a file FROM the server to your phone.
    Laura Knotek likes this.
    03-21-2016 07:51 PM
  1. Replies: 1
    Last Post: 03-22-2016, 12:31 AM
  2. HOW DO i GET RID OF THE PATTERN LOCK ON MY SAMSUNG GALAXY S6
    Last Post: 03-22-2016, 12:28 AM
  3. how do i get pictures off a "blank or unsupported sd card?"
    By Brittney Alver in forum Ask a Question
    Last Post: 03-21-2016, 07:38 PM
  4. Replies: 0
    Last Post: 03-21-2016, 06:39 PM
  5. Replies: 0
    Last Post: 03-21-2016, 06:25 PM
