1. AC Question's Avatar
    I have place a pattern code on my phone for security but keeping forgetting the code. I don'the want it and nowe don'the know how to deactivate
    03-22-2016 06:21 AM
  2. Trenglich's Avatar
    As far as I know you absolutely need the pattern to be able to change it. I don't believe there is any limit on the number of tries. Once you figure it out just go to your screen lock settings and switch to no security. It's more convenient but if you keep the phone in your pocket like I do it will get unlocked and apps will open. Like unintentional phone calls. I suggest you just change to an unlock pattern or code you can easily remember.
    03-22-2016 08:14 AM
  1. Replies: 1
    Last Post: 03-22-2016, 09:34 AM
  2. Replies: 1
    Last Post: 03-22-2016, 08:14 AM
  3. Replies: 0
    Last Post: 03-22-2016, 06:18 AM
  4. Replies: 0
    Last Post: 03-22-2016, 06:17 AM
  5. Replies: 0
    Last Post: 03-22-2016, 06:09 AM
