1. AC Question's Avatar
    Everytime I click on an app a pop up pop ups and says install for free and it shows a video on top with no sound explaining that app. The only way for me to get out of the pop up is to click the home button repeatedly until skip sign at the bottom shows up or click on the install for free button. The install for free button leads to the app store showing me the app that it recommended me to download. I just go back to the home page after and do what i was doing until it happens again. This happens all the time. Its been going on since the android upgraded to android 6.0.1. Please if anyone can help me I would be very happy.
    03-24-2016 02:12 AM
  2. spanish2's Avatar
    Check your installed apps....one of them must be the culprit......Uninstall one app at a time until you find the one at fault. Or you can do a factory data reset....make sure you back up anything you would want later on from the phone. Hope this helps.
    03-24-2016 02:23 AM
  1. How do I flash Sprint to a Straight Talk service?
    By AC Question in forum General Carrier Discussion
    Last Post: 08-29-2016, 10:04 PM
  2. Why won't the device manager let me do an unlock?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-03-2016, 03:16 PM
  3. Honor 6 mobile phone is not working when i remove charger
    Last Post: 03-26-2016, 02:28 AM
  4. Why is Android System draining my S7's battery?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-24-2016, 10:04 PM
  5. How do I delete contact "groups" from my phone storage?
    By AC Question in forum LG Android Phones
    Last Post: 03-24-2016, 02:11 AM
