1. AC Question's Avatar
    There is this blue box with the number 1 next to my send button when I send messages. And when the message is sent the blue 1 appears next to the message I sent or the messages I receive. What is it for?
    03-24-2016 07:58 AM
  2. srkmagnus's Avatar
    What phone and application (stock messaging, facebook messenger, etc.) are you using? It doesn't sound familiar, but hopefully additional information will help us identify it.
    03-24-2016 08:17 AM
  3. Angel Yuri's Avatar
    I'm using a Samsung s7 edge. Whenever I send text messages there is a 1 next to the send box.
    03-24-2016 08:26 AM
  4. kmj2551's Avatar
    I'm seeing the same exact thing. Galaxy S7 Edge running Marshmallow 6.0.1. In the stock messaging app there is a little blue box with a number 1 in it next to the Send button, as well as next to every single message. I've deleted all my messaging threads, cleared the app cache and data, as well as wiped the cached partition. The little box with a 1 is still there. Any ideas anyone?
    04-13-2016 10:32 AM
  5. ParkMeeHan's Avatar
    It is because some of the S7 edge models are dual-sim. You can choose to have a single sim and a memory sd card or dual sim. The blue box 1 is telling you which sim. I think this changes to 1 and 2 when you are in dual sim mode. I have not tried it.
    You can change it via SIM Card Manager
    05-19-2016 05:49 PM
  1. Training to build Android apps
    By DzCoder in forum Developer Beta Testing
    Last Post: 07-20-2016, 06:41 PM
  2. Replies: 5
    Last Post: 03-25-2016, 11:34 AM
  3. Volume button controls media, not ringtone volume
    Last Post: 03-24-2016, 08:31 AM
  4. Why does my Tablet S2 9.7 freeze then go into a restart?
    By AC Question in forum Samsung Galaxy Tab S2
    Last Post: 03-24-2016, 08:11 AM
  5. Replies: 0
