1. AC Question's Avatar
    I have a list of 400 names and numbers on my PC. I want to transfer all these contacts to a file e.g Excel and then sync them to my Android Phone as my phone contacts.
    I also want to share this file to my friends so they will have the file including 400 contacts and sync to their cell phones easily.
    Is it possible?!
    03-29-2016 05:08 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are these names and numbers in an address book program on the PC, or just in a document? If they're in an address book program, then there is probably a way to Export the data as a .CSV file. You can then import the .CSV file into Google Contacts: https://support.google.com/mail/answer/14024?hl=en
    If the information was just entered freehand as a document, then you could probably create your own .CSV file in Excel: https://support.google.com/mail/answer/12119?hl=en
    03-29-2016 03:44 PM
  1. Disable "Use usb for file transfers?" dialog?
    Last Post: 05-19-2016, 09:07 AM
  2. Replies: 1
    Last Post: 03-29-2016, 04:23 AM
  3. Where can i find the setting for unlock effect on my s7 edge
    Last Post: 03-29-2016, 03:45 AM
  4. Where can i find the setting for unlock effect on my s7 edge
    Last Post: 03-29-2016, 03:37 AM
  5. How to recover password for Note 5
    Last Post: 03-29-2016, 02:03 AM
