1. AC Question's Avatar
    Everytime i call it says not connected to network and not even *122# to check my credit works. it always says the same things.Its been Months since i used this sim card
    03-29-2016 08:37 AM
  2. anon(632115)'s Avatar
    Some providers' sim cards have a limited life span whether you have credit or not.If you haven't used it in months that may be your answer. I think you should speak to them for confirmation
    03-29-2016 10:02 AM
  1. Why won't some apps work on home wifi network?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 05-15-2016, 08:01 PM
  2. Why is my battery draining super fast when phone isn't in use?
    By AC Question in forum Hardware Hideaway
    Last Post: 04-02-2016, 01:27 AM
  3. Why isn't Active Sync connecting to the server after 6.0.1 upgrade?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-30-2016, 06:35 AM
  4. No move to SD card in Storage settings on Android 6.0?
    By AC Question in forum Legacy Android & Other OS's
    Last Post: 03-29-2016, 03:15 PM
  5. No "move to SD card" in Storage settings on Android 6.0
    Last Post: 03-29-2016, 08:10 AM
