1. AC Question's Avatar
    I've "forgot" a network that I want back.
    04-01-2016 03:54 PM
  2. Rukbat's Avatar
    Go to an area where the network shows, select it and set up whatever needs to be set up. (You can't set up - or "unforget" - a network you're not receiving.)
    Laura Knotek likes this.
    04-01-2016 04:49 PM
  3. Bergyo's Avatar
    It no longer shows up when I check available networks!
    04-01-2016 06:05 PM
  4. Bergyo's Avatar
    It no longer shows up! Yes, I'm where the network is.
    04-01-2016 06:07 PM
  5. ManiacJoe's Avatar
    You cannot "unforget". The only thing you can do is connect to it again.
    If the wifi network is not showing, you either have wifi turned off or the network is not available at that time.
    Laura Knotek and Greyduck15 like this.
    04-02-2016 01:32 AM
  6. arcticternmogz's Avatar
    (Samsung galaxy) Got an accidental forget of a bar's wifi. It happened a month ago. But when I go to the same bar, and friends' devices are working, the network appears in my list but saying "security status unknown" under it and nothing happens when I tap it.
    02-25-2017 04:13 PM
  7. Ry's Avatar
    Is it still there?
    02-25-2017 04:48 PM
  1. Replies: 96
    Last Post: 05-30-2016, 10:37 PM
  2. Replies: 1
    Last Post: 04-06-2016, 08:10 AM
  3. Replies: 1
    Last Post: 04-02-2016, 01:59 AM
  4. lg 441g can not connect to wifi
    Last Post: 04-01-2016, 04:43 PM
  5. Replies: 3
    Last Post: 04-01-2016, 04:05 PM
