1. AC Question's Avatar
    Hello there,
    i have a weird problem.
    Take a look at the following output from a adb root shell with busybox installed.
    DF
    Code:
    # busybox df -h
    Filesystem                Size      Used Available Use% Mounted on
    tmpfs                   179.0M     64.0k    178.9M   0% /dev
    tmpfs                   179.0M         0    179.0M   0% /mnt/asec
    tmpfs                   179.0M         0    179.0M   0% /mnt/obb
    /dev/block/mmcblk0p15
                            442.9M    224.5M    218.4M  51% /system
    /dev/block/mmcblk0p17
                              1.3G      1.2G     94.2M  93% /data
    /dev/block/mmcblk0p12
                              4.9M      4.1M    796.0k  84% /persist
    /dev/block/mmcblk0p16
                             98.4M      4.1M     94.4M   4% /cache
    /dev/block/mmcblk0p27
                              4.9M     44.0k      4.6M   1% /efs
    /dev/block/vold/179:28
                              5.0G      2.7G      2.3G  54% /mnt/sdcard
    /dev/block/vold/179:33
                              1.9G      1.1G    751.2M  61% /mnt/sdcard/external_sd
                              1.9G      1.1G    751.2M  61% /mnt/secure/asec
    /dev/block/dm-0          15.2M     14.1M      1.1M  93% /mnt/asec/com.nullsoft.winamp-1
    /dev/block/dm-1           2.0M    592.0k      1.5M  28% /mnt/asec/jackpal.androidterm-1
    /dev/block/dm-2           3.1M      2.0M      1.1M  66% /mnt/asec/com.ghisler.android.TotalCommander-2
    /dev/block/dm-3          23.3M     21.9M      1.5M  94% /mnt/asec/org.telegram.messenger-1
    /dev/block/dm-4           4.1M      2.5M      1.6M  61% /mnt/asec/com.valvesoftware.android.steam.community-2
    DU
    Code:
    # busybox du -sh /data/*
    56.0k   /data/anr
    1.4M    /data/app
    4.0k    /data/app-private
    68.0k   /data/backup
    1.7M    /data/busybox
    31.1M   /data/dalvik-cache
    20.7M   /data/data
    4.0k    /data/dontpanic
    4.0k    /data/gps
    4.0k    /data/gpsone_d
    8.0k    /data/local
    304.0k  /data/log
    4.0k    /data/lost+found
    96.0k   /data/misc
    24.0k   /data/property
    8.0k    /data/radio
    8.0k    /data/secure
    4.0k    /data/shared
    4.0k    /data/situation.txt
    4.0k    /data/stream_bluetooth.txt
    4.0k    /data/stream_headset.txt
    4.0k    /data/stream_speaker.txt
    428.0k  /data/system
    444.0k  /data/tombstones
    4.0k    /data/wifi
    4.0k    /data/wiper
    4.0k    /data/wpstiles
    56.3M   /data
    MOUNT
    Code:
    # busybox mount
    rootfs on / type rootfs (ro,relatime)
    tmpfs on /dev type tmpfs (rw,relatime,mode=755)
    devpts on /dev/pts type devpts (rw,relatime,mode=600)
    proc on /proc type proc (rw,relatime)
    sysfs on /sys type sysfs (rw,relatime)
    none on /acct type cgroup (rw,relatime,cpuacct)
    tmpfs on /mnt/asec type tmpfs (rw,relatime,mode=755,gid=1000)
    tmpfs on /mnt/obb type tmpfs (rw,relatime,mode=755,gid=1000)
    none on /dev/cpuctl type cgroup (rw,relatime,cpu)
    /dev/block/mmcblk0p15 on /system type ext4 (ro,relatime,barrier=1,data=ordered)
    /dev/block/mmcblk0p17 on /data type ext4 (rw,nosuid,nodev,noatime,errors=continue,barrier=1,data=ordered)
    /dev/block/mmcblk0p12 on /persist type ext4 (rw,nosuid,nodev,relatime,barrier=0,data=ordered)
    /dev/block/mmcblk0p16 on /cache type ext4 (rw,nosuid,nodev,noatime,errors=continue,barrier=1,data=ordered)
    /dev/block/mmcblk0p27 on /efs type ext4 (rw,nosuid,nodev,relatime,barrier=0,data=writeback)
    /dev/block/vold/179:28 on /mnt/sdcard type vfat (rw,dirsync,nosuid,nodev,noexec,noatime,nodiratime,uid=1000,gid=1015,fmask=0002,dmask=0002,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro)
    /dev/block/vold/179:33 on /mnt/sdcard/external_sd type vfat (rw,dirsync,nosuid,nodev,noexec,noatime,nodiratime,uid=1000,gid=1015,fmask=0002,dmask=0002,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro)
    /dev/block/vold/179:33 on /mnt/secure/asec type vfat (rw,dirsync,nosuid,nodev,noexec,noatime,nodiratime,uid=1000,gid=1015,fmask=0002,dmask=0002,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro)
    tmpfs on /mnt/sdcard/external_sd/.android_secure type tmpfs (ro,relatime,size=0k,mode=000)
    /dev/block/dm-0 on /mnt/asec/com.nullsoft.winamp-1 type vfat (ro,dirsync,nosuid,nodev,relatime,uid=1000,fmask=0222,dmask=0222,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro)
    /dev/block/dm-1 on /mnt/asec/jackpal.androidterm-1 type vfat (ro,dirsync,nosuid,nodev,relatime,uid=1000,fmask=0222,dmask=0222,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro)
    /dev/block/dm-2 on /mnt/asec/com.ghisler.android.TotalCommander-2 type vfat (ro,dirsync,nosuid,nodev,relatime,uid=1000,fmask=0222,dmask=0222,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro)
    /dev/block/dm-3 on /mnt/asec/org.telegram.messenger-1 type vfat (ro,dirsync,nosuid,nodev,relatime,uid=1000,fmask=0222,dmask=0222,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro)
    /dev/block/dm-4 on /mnt/asec/com.valvesoftware.android.steam.community-2 type vfat (ro,dirsync,nosuid,nodev,relatime,uid=1000,fmask=0222,dmask=0222,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro)
    So these two calls show two important information:
    df is reporting memory block "/dev/block/mmcblk0p17" as 1.3G in size and 1.2G IN USE! mounted on /data
    du is reporting 56M in use for /data
    mount is not showing anything else hooked into /data
    So where is the missing 1.15G storage space that is IN USE!?
    P.S. I am unable to create an account here on the site. So any helpful information can be posted, i will monitor this post for answers.
    04-04-2016 03:12 PM
  2. Laura Knotek's Avatar
    Welcome to Android Central.
    Have you tried checking this link to create an account?
    04-04-2016 03:15 PM
  3. Laura Knotek's Avatar
    04-04-2016 03:15 PM
  1. Why can't I save images from Tumblr since update to 6.0.1?
    By AC Question in forum Legacy Android & Other OS's
    Last Post: 12-03-2016, 05:46 AM
  2. Replies: 8
    Last Post: 04-06-2016, 11:31 AM
  3. How do I clear closed programs from memory, Samsung Galaxy S4?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-04-2016, 11:28 PM
  4. i cant open my phone settings and certain apps
    Last Post: 04-04-2016, 03:13 PM
  5. Missed Calls notification only says 'Phone'?
    By AC Question in forum More Samsung Phones
    Last Post: 04-04-2016, 01:51 PM
