1. Lamensterms's Avatar
    Hi,
    Does anyone know how I can create a homescreen widget/shortcut that will start a countdown timer?
    I'd like to have a variety of shortcuts on my home screen that start times (in the clock app). For example, I could have one shortcut to start a 1 minute timer, another shortcut to start a 5 minute timer, etc.
    I'm using Total Launcher with the More Shortcuts app, but can't find anything in there that might get the job done.
    Thanks for any help.
    04-04-2016 09:02 PM
  2. CherryR's Avatar
    You could try the:
    Multi Timer StopWatch How can I create a homescreen widget/shortcut that will start a countdown timer?-aafc73031c77d9237532cf4dae3ac851_icon_96x96.png
    Or
    Ok Timer How can I create a homescreen widget/shortcut that will start a countdown timer?-ok-timerandroidiha.com_.png
    Tell me if any of these helped or not!
    04-05-2016 05:43 AM
  3. Lamensterms's Avatar
    Thanks Cherry. Both those apps support the feature I'm looking for. Limited to 3 timer times for OK Timer.
    Thanks for the recommendations.
    04-05-2016 06:42 AM
  4. CherryR's Avatar
    You're welcome, glad I could help!
    04-08-2016 12:46 AM
  1. How do I send a file from my Android phone to Windows 7?
    Last Post: 04-05-2016, 03:34 PM
  2. BestBuy selling unlocked S7 Edge - will Samsung Pay work?
    By digitalbreak in forum Samsung Galaxy S7 edge
    Last Post: 04-04-2016, 09:19 PM
  3. broken screen (lcd) can i charge it
    Last Post: 04-04-2016, 08:04 PM
  4. Broken lcd screen, can I charge it?
    By leah12345678 in forum Samsung Galaxy S6 edge+
    Last Post: 04-04-2016, 08:02 PM
  5. I can no longer see my file extensions in my files app, why?
    By AC Question in forum Samsung Galaxy Tab
    Last Post: 04-04-2016, 07:34 PM
