1. AC Question's Avatar
    HI
    i want to connect a 5.1 DAC to hear full channel output, please suggest me an app and the right device.
    I already have a Galaxy S3, S4 & Huawei Honor 7
    Please sugget
    04-07-2016 06:49 AM
  2. kramer5150's Avatar
    You could use a DAC like the audioengine D1 to convert the bit stream from USB to toslink, from there feed the optical signal to a dedicated 5.1 HT receiver. Its been ages since I researched HT gear, but there might be HT receivers that are compatible with USB out, and do the DAC process internally.
    Android 5.0 Lollipop supports USB DAC audio devices, we go ears-on
    D1 24-bit DAC
    A lot of HT receivers have USB inputs. but I don't know how universal that is, whether its set up to receive data from PC, thumb drive, external USB drive... or android phone.
    04-07-2016 12:35 PM
  1. Replies: 3
    Last Post: 08-07-2017, 10:45 AM
  2. Replies: 3
    Last Post: 08-08-2016, 12:27 PM
  3. Can anyone help stop my Tecno F8 from installing apps automatically.
    By Cletus Kanu Nwokoro in forum Ask a Question
    Last Post: 04-07-2016, 09:10 AM
  4. My Android is laying down with a red sign, how do I fix this?
    Last Post: 04-07-2016, 07:05 AM
  5. Replies: 2
    Last Post: 04-07-2016, 07:01 AM
