Originally Posted by
Fasi Ahmed My Micromax canvas A1 mobile is on android-6.0 version. Today I tried to factory reset my mobile and completed reset. After reset rebooted my mobile and it went through language selection screen. Selected wi-fi connection and clicked on next, it stuck on "Checking connection..." screen. I tried with mobile network as well, but no use.
Tried restart no luck. Tried factory reset again still facing the same problem.
How to fix this ?
Welcome to Android Central!
Are you able to skip that stem and get in to the phone? You might need to go in and enter in your networks APN settings. Not sure why the wifi is not working, are you running a custom ROM like CM?
