1. AC Question's Avatar
    I cannot do a lot of things on phone keep getting a andriod.com settings not working
    04-15-2016 05:56 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Does this persist after a reboot? If so, try booting into Safe Mode, which temporarily disables all 3rd party apps. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    04-18-2016 03:18 AM
  1. Replies: 1
    Last Post: 04-18-2016, 03:23 AM
  2. Replies: 1
    Last Post: 04-18-2016, 03:20 AM
  3. How do I enable a bug report?
    Last Post: 04-15-2016, 06:11 AM
  4. how to enable bug report
  5. Why can I not get my phone back to factory settings?
    By AC Question in forum Alcatel One Touch Fierce
    Last Post: 04-15-2016, 05:23 AM
